Old 09-30-2007, 01:04 PM
fsstnotch fsstnotch is offline
Originally Posted by Rick Parker
.0125 is a HUGE dimension here. Many demand a .0004 - .0008 smaller bore than the diameter of the snout, to create a "Press Fit". A vibration damper should NOT be able to be slip fit but rather require being pulled on with a Balancer installer. It has to have a tight fit to tranfer the vibration and allow the vibration to be absorbed by the Balancer, especially in an externally balanced application. The key alone will not be able transfer or accept the forced. Your fractured sleeve is evidence. Consider yourself lucky.
Ya, luckily it also went out as i was pulling onto my street and I was able to coast all the way to my driveway! No damage other than the balancer. I thought when i was installing it that "something wasn't right.. this should press on?" But it was late and I needed to drive the car the next day to work. Luckily for me that no permanent damage was done!
Bagram AF Afghanistan
