Old 09-30-2007, 01:45 PM
kris-kincaid's Avatar
kris-kincaid kris-kincaid is offline
Cobra Make, Engine: 427 SC
Send a message via AIM to kris-kincaid Send a message via Skype™ to kris-kincaid
Thanks for all the replies fellas.
Rich, I was thinking the same thing, but now I'm less interested in it after seeing it has a 1" piston. dang.
Jeff, when Googling, Pantera consistently came to the top, so I looked into it. If I'm seeing it properly, the slave is on the right side top of the bellhousing. That won't work with a std. RWD Ford bellhousing, correct?
Roger, I don't like the 1" bore either. I think I'll just buy a slave from you and fab my own brackets. I'll contact you.
Richard, the Autoworks Racing setup is really trick, but it seems to be for modern 5 speeds only. Plus it looks a little spendy for a cheapskate like me!
767Jockey, I'm not sure if the C and W have similar mounting areas around the bellhousing. I'm just going to make my own brackets.
