Old 10-01-2007, 02:57 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Do you use the thin sandvich plate between Bell housing & Block, could it have been bent while out and is now just touching the front face of flywheel - does the relief now stand proud of the block surface & warp that plate - has the starter ever 'kicked back' from an over advance ignition start, I have seen this bend those plates & cause the problems you speak of.
Jac Mac
