Old 10-01-2007, 06:48 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Jac,
What do you mean by crank end float? Throw out bearing possible, hell I have a new pilot bushing on the way to replace it any way when Saturday comes around.
I would have to say that it does not make a noise when rolling with the motor off. with clutch engaged. I will have to test to be sure. Again it does not happen all the time. If I shock the tranny by releasing the clucth suddenly that might fix it for a while but it will come back. When I take down the tranny I will inspect everything.
Tilton is saying that there is air still in the system because I bleed the system with the pedal stop in place.
Do you think it could be a pilot bearing ????????????????
Mike,
I dont see any way to put the Tilton unit on backwards.
