Old 10-02-2007, 07:18 AM
Automan Automan is offline
Default 4 spd Toploader in an Antique and collectable
Did anyone else put a toploader in thier kit? The positioning of my shifter doesn't look like the rest of yours. It still doesn't stick out enough. I put an aluminum spacer about 1 inch high between the shifter and the base of my shifter but it still isn't high enough. The top of the shifter cover is still on the angled portion of the handle. Because of the spacer, it has also caused the travel distance from first to 2nd to be greater. That it actually hits the ring when it is shifted to second. im afraid to add a higher spacer because it will probably increase the travel even further where i wont be able to get it into gear.
Things make you you go hmmmmmmmmmm'
Automan
