Old 10-02-2007, 07:54 AM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Go get a couple of inexpensive resistors (33 and 240 ohms, or as close as possible within that range) at Radio Shack and attach each resistor to the gauge terminals. This will at least tell you if the gauge is working properly.
If your test meter is working properly, disconnect the sender from the gauge and measure the sender resistance with the test meter. Good grounds are necessary. Check the accuracy and stability of the test meter by measuring the resistance of the two resistors you got at Radio Shack.
Warren
