Originally Posted by enyawix
18 degrees initial on what fuel?
We are running 92 octane pump gas. I pulled a drum fuel monster out of this car to be able to run pump gas. The c/r is 8.2/1 with pretty much stock crate engine other than a cam change.
You seem shocked at 18 degrees but many are running locked distributors and int he 24 to 28 degree range from scanning all the turbo web sites. I have years of blown engine history and it would be common to run up to about 32 degrees with a fixed mag and no mechanical advance. I am learning boost is not just boost as the turbo are a different critter than my roots type blowers.
jeff C
