Old 10-02-2007, 08:50 PM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
Before buying another fan or fully ducting the radiator, you should check the basics.
I would verify that the thermostat opens at the expected temperature, and that it opens fully.
I would also verify the temperature gauge readings. If the gauge is reading 20 degrees high you could go nuts trying to fix it with air flow.
Jim
A Gnat! Quick, get a sledgehammer!
