Thread: Changing oil
Old 10-03-2007, 09:05 AM
patrickt patrickt is offline
Originally Posted by CBattaglia
IDo you clear out all of the lines to get all of the oil out? I feel a bit uncomfortable leaving any old oil in the system.
You do not have to clear out the lines. If you just tilt the front end up a little bit by jacking the front end up, remove the oil filter and drain plug, and let it drain until it quits drizzling out the hole, you'll be just fine. Don't worry about the oil that doesn't come out -- you never ever get 100% of the oil out on an oil change.
