Old 08-22-2001, 12:46 AM
spencer spencer is offline
Cool If you really want to....
Petek...
If you really want to be able to adjust the front end maybe you should invest in a product from Pole Position Racing Products. They make a unit "Fastrax" that will allow you to adjust the camber / caster and toe in/out. I use it to play with the adjustments of my car at the track. It's really simple to use and you will learn quite alot about your chassis set up for street vs track. They also make adjustable upper control arms, these units make it a snap to make changes without dealing with the two bolts that secure to arm to the upper chassis. Their web site address is "www.polepositionrp.com". I deal with a guy named Ted. Give him a call and see what your options are.
Take Care....
Spencer
