Old 10-05-2007, 10:03 AM
Automan Automan is offline
Default Front rotor issues
Everyone out there must be just thinking that this guy probably should of bought a Yugo. HAHa
Ok, so here i am doing another run with alittle bit more confidence. Engine is running the best ever. I start hearing a slight thumping and then i start feeling it on my stearing wheel. I have a manual rack. I pull over to the side and start doing the checks. Wheel nuts are good, lwers, uppers, tierods etc.
Nothing is popping out at me. So i continue with my run but start heading back home. about another mile and it comes back but way worse. I pull over and see that my driverside tire is angled slightly. I look at the rim and oh my God!!! i am now missing 3 studs along with the wheel nuts. The other two are loose. I start walking back and find two studs and one wheel nut. Called the wife and she brought out the jack and tire iron. Pulled off the tire and the rotro hub holes are completely smooth. No signs at all of spline markings to hld the studs. I slide the studs back in and tighten the wheel back on to the best that i can. So curiousity sets in and i go check the passengers side and one stud is also loose. Got it back home very slowly with a few stops to re tighten the nuts. Yes they are loosening up.
Well guys! What do you think? I thinnk that the manufactures of the rotors didn't put any splines in these rotors or missed at least 3 on one and one on the other.
Automan (please stop laughing haha)
