Originally Posted by Automan
Did anyone else put a toploader in thier kit? The positioning of my shifter doesn't look like the rest of yours. It still doesn't stick out enough. I put an aluminum spacer about 1 inch high between the shifter and the base of my shifter but it still isn't high enough. The top of the shifter cover is still on the angled portion of the handle. Because of the spacer, it has also caused the travel distance from first to 2nd to be greater. That it actually hits the ring when it is shifted to second. im afraid to add a higher spacer because it will probably increase the travel even further where i wont be able to get it into gear.
Things make you you go hmmmmmmmmmm'
Automan
I used a '66 Galaxie Top Loader (long tailshaft) with a 289 style shifter in my ERA 427. While not optimal, it seems to fit fine. After I get it sorted, I'll change to a 427 style shifter. Check my gallery, the shifter location is much like yours.
