Old 10-08-2007, 06:10 PM
onefastmustang's Avatar
onefastmustang onefastmustang is offline
Cobra Make, Engine: CRII with a Stroked Windsor
Originally Posted by Rick Parker
If the ground electrode has been impacted and is crushed against the center electrode, then you probably have a broken piston. Sometimes the tops separate right above the ringlands (this was an issue with some of the OEM stroker pistons) it has been documented, and discussed here previously......sorry.
You are correct. That's exactly what happened.. Maybe I need to change piston manufacturers. I guess the block comes out this weekend and I rebuild it. I had speedpro hyp pistons in there. I guess another brand/type is advisable at this point..
