Thread: Rumbling diff!!
Old 10-08-2007, 11:05 PM
David Hodgson's Avatar
David Hodgson David Hodgson is offline
Hi Slowy,
The diff being mounted directly to the chassis, ie metal to metal without insulators (rubber bushes) will transfer all mechanical noise. This was amplified when I fitted the hollow roll bar. my plan is to foam fill the bar to reduce the noise.
Mine and others that i have heard that have recond. diffs, emitt a whiring/meshing noise.
I would not worry unless it is accompanied by a grinding noise.
I have seen a couple of U.S kits that use a large bush on the top mount instead of direct plate.
SLIPRY
