Old 10-10-2007, 07:12 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
I looked at your gallery, and if you remove the quad shocks, you can narrow it a little , but I believe that you don't have a lot of room with your set up.
And 8.8 axles can't be cut down because they use C clips---if you do narrow the rear convert to a Torino type housing end to eliminate the c clips and upgrade to 31 spline axles
Jerry
