Old 10-10-2007, 12:46 PM
B L & sons B L & sons is offline
Thanks for the help
Jerry.I have installed upper and lower adjustable control arm so I do not think the quad shock will be any advantage I well remove them,I need the room.
I was under the impression that I could narrow a 8.8,or is it like Ron61 recommends with the upgrade to 31 spline axle and a Eaton posi then it could narrowed.
Looks like the way to go is by what Rick has recommended .The rear has to come out one way or the other.After it is out I will measure from inside fender lip left to right.would any of you konw what the normal measurement should be? give or take
Thanks for your help
Bill
