Thread: So Close
Old 10-10-2007, 02:16 PM
07cob's Avatar
07cob 07cob is offline
Default Cheers
Paul
Just have to do a wheel alignment and then get through all the red tape.
The RH mirror is OK, the left is a passenger! If I had the option, I would mount both mirrors on the screen – as high as possible. I actually don’t mind the look.
I went with the standard AVO/King setup from Warwick for the shocks. Here’s a side shot for you.
Stephen
The mirrors are just mounted through the 'glass with a large (curved) washer on the inside for a backing plate. As Paul says – go the screen mounts if you actually want to see. I haven’t really tested mine, but the LH will be all but useless – despite many hours of ‘dry’ testing.
El Prez - Don’t worry about me on the track – I’ll be so far away from you that you won’t even see me!!
Craig - I am supposed to be heading up for the alignment and hoist review later today (weather permitting). I should be doing the alignment on the weekend.
Cheers all
Geof
