10-10-2007, 07:21 PM
NH
Originally Posted by cobrajam
Yes, I had seen all of your info on upgrading the radiator, but I am starting from ground zero, no radiator, brackets, mounts, etc., anything to upgrade from. I kind of have an idea how to mount from looking at ERAs site, but all of that will have to be fabricated. What is the recommended radiator size? I have a 28" wide X 18.5" tall. It will fit snug between the front frame, but may be able to make it work. Thanks
I think your idea of a channel top and bottom is a good one to attach the mounting pins to. I would make them in aluminum and just weld them to the radiator. Then you could bracket to the top and bottom pins like an original set up. If the original type look isn't of concern I'm sure we can come up with a simpler installation method. It sounds like a GM cross flow radiator, does it have a cap on the top of the left header tank?
