Old 10-10-2007, 09:34 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
You should not have to bleed anything, on an ERA the coolant tank is the highest point of the cooling system and once the stat opens all the air should be gone. If the timing is retarded that could be one reason for running hot. One other thing, make sure the fan is turning the correct way.
