Old 10-11-2007, 08:34 PM
sideshow sideshow is offline
they usually all have 3 lines
middle one is charcoal canister vent
the pip ethat uis snapped on yours is either return or feed
either try to screw a pipe onto the broken bit or buy a new pump
i personally would buy a new pump
60 psi of fuel pressure is probably not a good thing to have a pipe break and fuel go everywhere
about 1 in every 5 2nd hand fuel pump assemblies i work on have broken bits
then u have to make sure u get the corect fuel gauge to match the feul level sender in the hiolden pump assembly
another prob is holden changed the reistance values half way thru vy pumps depending if hsv or monaro or std
most guys who i wire up fuel level gauges always get the wrong type
my website
www.sideshowsperformancewiring.com.au
