Old 10-12-2007, 06:31 AM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Talking
Originally Posted by Tday
Am looking hard at SPF #1050...built in 2001...a beautiful and beautifully cared for car with 4K miles...
Are there major SPF changes since 2001 that you'd should care about if you were buying? I'm not asking about motor and transmission but the SPF part of the build.
Thanks, Tom
Tom, I have #1052 and Dean is right on about the brakes. I tried adjusting and it worked marginally; but never on any sort of grade, however. I sprung for the $500 upgrade kit (driveshaft-mounted disc type). Other than that, I switched to poly motor mounts after the 460's torque kept breaking the RH exhaust mounts, switched to poly swaybar bushings, and S/S braided brake lines. Good luck!
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
