Old 10-12-2007, 12:00 PM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
Originally Posted by BDHE
Greg;
Can you share the specs you gave them for the replacement shafts?
Bryon
I don't know the specs.
The Driveshaft Shop does the broken half shafts for Superformance regularly. They should know the correct specs if you tell them which rear end you have. As I understand they're down the street from the Olthoff facility. Maybe call the Olthoffs, www.olthoffracing.com ,for a reference and to identify the correct rear end in your car. I have the Ford 8.8 rear end which use to be used in the Superformance. Your car should have the new type of rear end. You might want to take a picture of your rear end and show it to someone familiar with the rear end types used in Superformance to be completely certain before ordering, but I strongly suspect you have the new type.
