Old 10-13-2007, 01:51 PM
shelby racer's Avatar
shelby racer shelby racer is offline
Cobra Make, Engine: Shelby CSX4788 with a Dawkins performance 490 ci iron genesis block hydrualic roller
Default Had to replace the master cylinder
After getting the old master cylinder back from my cobra guy, it still would not push or flow fluid. He came up and spent a couple of house fussing with it, taking it out, taking it apart, checking its function, putting it in, checking it, taking it out........ We finally gave up and I ordered a new cnc steel 3/4" master from left hander chassis to replace the aluminum afco that came with the car. We will see how it works out. It moves some fuid, but I am not sure if it is enough. I can not get the clutch to disengage the tranny with from the motor with the tranny in gear and the clutch in. It may be that the clutch disc has stuck to the flywheel (as I found out it had when I replaced the bell housing with this trick scatter shield I got from Bruce at Modern Driveline. I have tried to start the beast with no success but that I think is a topic for the next thread I need to start.
Racing, bull fighting and mountain climbing are the only true sports, everything else is just a game. - Hemmingway
