Old 10-13-2007, 01:52 PM
Barry_R Barry_R is offline
He must have another engine - that trick won't work with an FE.
The Fel-Pro race intake gaskets are just that - race gaskets that are designed for easy trimming to match modified ports on engines that will see frequent service. They simply will not hold up to regular street use.
If you don't like the way the Victor - or the equally good Fel-Pro passenger car gaskets stick out at the ends - you can mark and trim the very end off with the band saw before installing them. I do that all the time.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
