Old 10-14-2007, 02:09 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Dont suppose you checked the cam timing before you pulled it to bits. If you have not stripped it down that far yet, do that now and then refit one head and check the valve to piston clearance. Then & only then can you stand there with confidence and argue your case if both or one of those scenarios is correct. You owe it to yourself & the engine builder to do at least that much.
Jac Mac
