Old 08-23-2001, 06:33 PM
dakota dakota is offline
Thanks!! That's the way I was going to do it, but I had read one of the threads on this, and it was said to be sure to run a ground wire from the trunk mounted battery to the engine. I've never had a problem grounding each to the frame before, but I thought someone else may have had a problem doing it that way.
I got the battery dimensions now, but I would appreciate if you could post a picture of your install.
Thanks,
Wade
