Old 10-16-2007, 06:40 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
Originally Posted by blykins
You found a set of Probes to work with your deck height? That's great....they're good pieces and are very nicely priced.
However, now that I read your post, I'd suggest against using a .060" gasket if you're planning on putting the pistons back down in the hole where they belong. That's a pretty big quench distance.
If you need help selecting a cam, let me know.
I assume the 0.060" gasket is to deal with the piston out the top problem with the block- the numbers given suggest that- 4" stroke, 1.280" pin h, 6.200" rod =9.480" therefore 9.465 block + 0.060" gasket= 9.525(0.045" piston to head).
Jac Mac
