Old 10-17-2007, 08:03 PM
Bob In Ct's Avatar
Bob In Ct Bob In Ct is offline
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Tell your friend to try to run a 50/50 blend of water and antifreeze since, as it was earlier stated, this will raise the BP of the coolant mixture significantly. It will also lubricate the water pump and will slow down corrosion.
Synthetic oil also tends to tolerate heat better than does dyno oil.
What really amazes me is that your friend did not just pull over and turn it off.
Bob
