Best jet size, etc ?? 650 Holley 302 Ford crate
Would really like to hear from someone who has the same engine..I recently bought a cobra with 302 Ford Racing 340HP came with 650 Holley double pumper # 4777-7 stamped on horn with mechanical secondary. Car doesn't seem to run right almost 99% sure it is carb related, stumbles etc... fuel pressure is 4 lbs has a electric Carter fuel pump Part #06K20A & P61296 on sticker looks to have plenty of flow, plugs look to be proper color.
What size jets would you run in primary-secondary and what other mods to carb would you recommend such as power valve-whistles in bowls.. best rebuild kit Barry Grant?? Its been 20 years since I last worked on a Holley which was mounted on a supercharged 1985 Mustang GT.. I am a little rusty..
I am going to remove it and check it over so it would be great if I knew the best set up so I can get proper jets, etc.. Car is strictly used on street not a dedicated racer..
Like a kid in the candy store I just can't get enough
Current rides GT500 & Backdraft
