Old 10-18-2007, 05:21 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by priobe
I would like to find out if this is a good cam or if I should think about tossing it and installing a new one.
Intake
Lobe Separation = 111.9
Valve overlap= 23.4
Valve open 14.6
Center line= 115.8
Valve close= 50.2
Duration: 244.37
Lobe Lift= .65956
Lobe area 30.85
Exhaust
Valve open = 60.5
Centerline = 115.8
Valve Close = 8.9
Duration 249.3
Lobe lift .3789
lobe Area 31.83
Second document
Intake 245 @.050
Exhaust 250 @.050
.650 Lift
Compression 9.5
You need to talk to a weber guru, as that induction system seems to benefit / depend upon specific cam specs.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
