Thread: Leaks all over
Old 10-20-2007, 10:59 AM
TRIG's Avatar
TRIG TRIG is offline
Cobra Make, Engine: SPF2275 #50 of the anniversary edition cars. Roush 427R TKO600
you can bleed the clutch at the slave where it's connected to the clutch fork. Very simple, just have someone sit in the car and push the clutch to the floor the turn the bleed screw to let the air and fluid out, tighten the screw, release the clutch pedal, push it back in, turn the bleed screw, tighten it and so forth. You get the picture. Once you get all the air out top off the clutch resivoir.
trig2275
