Thread: 351w
Old 10-20-2007, 11:40 PM
Sydney Sydney is offline
Cobra Make, Engine: Shell Valley, 351W
Hi Stefan,
The Lokar KD2AODHT AOD kickdown kit works well. It requires the Lokar SRK 4000 cable bracket also. The flexplate depends on your engine balance, 28 oz, or 50 oz. 164 tooth 14 1/4" diameter. Ebay usually has SFI certified ones in both weights. You will also need a block plate to go between the engine and transmission. Ford F4TZ-7007-A works ok. Good luck.
Sydney
