Thread: Leaks all over
Old 10-21-2007, 02:36 PM
patrickt patrickt is offline
Originally Posted by mrp_e
Is it possible ... already needs a new clutch slave cylinder?
Yes, it's possible. But check the fittings and threads first. Maybe they're loose or didn't have the proper sealant on them. Changing out the slave is actually pretty simple. Just a couple of bolts, hook up the fluid line, and adjust the slave-rod/fork/TOB clearance as per my link above. A leak of that size should be pretty easy to isolate. If it's not already obvious where the leak is, just clean everything up and wrap a little white gauze around the fittings, etc. and let it sit overnight (don't drive it around). That should tell you where it's leaking.
