Old 10-21-2007, 01:52 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Timing on 427 SO advance question
Hello,
I would like to know if this is normal. I am running a MSD dist. with coil. I went to shoot time and noticed that my timing was set at 12 degree. I went and verified the bushing and springs which are silver. This should put my timing around 37 degrees. As I rev the motor I noticed that my timing only moves 2 degrees from 12. I also noticed that the timing is moving backward from 12 to 10 ( also toward TDC) on my ATI balancer.
Is this normal?
Also, what could cause the dist not to advance?
