Thread: Dry sump
Old 10-22-2007, 06:53 AM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Rick
As long as the line coming out of the pump on the pressure side is higher then the level of the oil in the tank....... you're OK..... like going up to the oil filter on a cross bar between the shock mounts.....
Dry Sump tanks like to find their own level....(they will blow oil out the breather until they find the level they want to be at)......... inside the tank..... and it's usually about a 1/2" below the baffle plates...... while the motor is running....
Morris
Morris
