Old 10-22-2007, 10:48 AM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Originally Posted by wrench87
do you remenmber if you used new or old driveshaft bolts?, i have heard of a lot of people find loose driveshaft bolts when they were used , the new ones have lock tite on them. also check the the crankshaft bolt at the balancer.
I checked the driveshaft bolts and everything is tight. I never thought about the crankshaft bolt, better check it. Would that cause a vibration if the bolt was loose? Isn't the balancer key'd?
--Mike
