Old 10-23-2007, 07:38 AM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Originally Posted by carmine
Mike; does the vibration go away or become less as your rpms go above aprox 2400 rpm.
No, but I wish it would. It does seem to level off a bit when the rpm's get high enough.....maybe around 3000 or so. It's really driving me nuts. I will figure it out in the end, but I believe I'm in for a long search. If I had to describe the vibration, I would say that it is not present at idle. It builds starting just slightly on throttle and is pitched with the RPM's. The engine vibration is not noticeable by eye, but is definitely coming from the engine, accessories or bellhousing area. The engine performance is normal with a steady idle, no back-fires, rough idle, stumbling etc. It almost feels like the timing is off if you know what I mean. Something is not balanced or the adjustment is off.
--Mike
