Old 10-24-2007, 07:07 AM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
With the current set up you will need to remove the cross member that the transmission bolts onto. I am opposed to cutting up the frame... That is why our 5 speed mount is the way it is.
I am also working with a gear manf to see if it is possible to shorten the bell housing and make everything fit.
Also the T56 gear ratios are not the best... Unless you use Rocklands or G-Forces gears (not cheap). I am also looking at a more wallet friendly way of getting better gear ratios for the T56...
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
