Old 10-24-2007, 11:49 AM
Default What dampener is on the car?
Carmine What dampener is on the motor? Stock, ATI, Any markings? I will still go with the clutch assembly. Pulling the trans and clutch itself would be the first place to try and locate the vibration. It could be a bad bearing in the water pump, pulley not spinning true on the crank, If this problem just started I would stay with the clutch and flywheel first. Rick L.
