Thread: tire pressures
Old 10-24-2007, 12:54 PM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
For what you are asking, the BMW based suspension really doesn't mean any thing. Unless BDR has tested your setup on your tires and come up with a recomendation (did you ask them) then you are asking for some one else's personal preference. BFG has this formula:
(Vehicle Weight in lb/100) + 2 psi at heavier end + 2 psi all around if suspension and alignment are stock.
Example: 2800 pound car
(3000/100) = 28 psi
Add 2 psi all around = 30 psi
Add 2 psi to heavy end = 32 psi at rear
Many find that high, put plug in yours numbers and see what you think. Play with them up and down a few pounds and try again. Have fun!
OhioCobraClub.com
LondonCobraShow.com
