Old 10-24-2007, 10:35 PM
Rebel1 Rebel1 is offline
Yep..pretty close to my start point for the front Craig.
If I remember the previous owner told me the car was great on a smooth highway by a bit nervous on an undulating road.
One of the problems with the RMC is the variation of the placement upper arm mounting.
My car has the two bolts holding the upper arm above the bottom of the front chassis cross member. If you look at the picture in Ross Smiths gallery at his chassis pic you'll notice the same holes are below the cross member.
Whilst not an issue at rest Ross's car will invoke negative camber with less body roll which is exactly what you want.
Sadly the RMC chassis varies quite a bit.
