Old 10-24-2007, 10:33 PM
Rebel1 Rebel1 is offline
Originally Posted by stephen low
Les
My fellow indicated that use of some rose joint movement ok for the rear, that's why they have bushes and rubbers, but there is a limit to what can be achieved.
In my case he is of the opinion that 1 - 2 turns of my LH rose joint is all that is needed to get toe in so both rear tyres are at about similar angles. This overcomes any later dabbling with the rear axle, given the out of line mounting hole issues for RMC and G Force cars.
Interesting to see you quote positive camber though.
Nope, not in favor of any "pulling" to achieve your geometry. There are enough stresses both fore and aft for the rubber bush to deal with as it is. Using it to pull the toe will only cause wear of the bush and then you are back to square one.
The geometry can be perfectly set using the shims and that leaves the trailing arm to deal with it's own problems. In the case of the RMC it runs straight forward so will pull on squat and rebound anyways.
The positive camber was just a starting point and depends on your top mounting point. Static positive camber in some cases can quickly turn negative with very minor body roll.
