Old 10-25-2007, 05:27 AM
sideoiler10 sideoiler10 is offline
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
Default Ford 9"
Yes, you have to press the bearings on the axles. The bearings I use have the seal, which is an o-ring, that is set into and around the outer edge of the bearings. I don't recall the bearing part numbers or specs, but I have the information and can probably find it if you need it. If you don't have the tool to press on the bearings, almost any shop can do it for you.
I had a seal that was starting to leak slightly about 4 years ago so I replaced both rear bearings and seals and everything has been dry since.
You can get the part number off your old bearing to order replacements.
Easy fix. Good luck, Bob
