Old 10-25-2007, 06:07 AM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Originally Posted by carmine
Interesting what you mention about the mounts, had that same problem with the right side, then changed to poly mounts from Olthoffs but vibration still there. What do you mean by you ( welded the mounts ). regards Carmine
I welded the broken piece on the sidepipe mount, then I bent a cut piece of .5" round steel rod to the same angle as the sidepipe mount, then welded that to the underside of the mount to reinforce it. Ground it down to finish it and painted it hi temp black. Make sure you use a welding blanket to protect the door and sill paint...
Actually, the new mounts transmit more of the engine resonance now than it did before. It's throughout the entire range, however. I feel it more on the seatback and can get annoying on a long drive. It got rid of a drone I had between 2400 and 3500, though. I suspect that was the broken motor mount. I guess it's a trade off for the crispier feel and seemingly more immediate response I get.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
