Old 10-25-2007, 08:47 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Loadco-
I was looking at your pics and noticed that because you mounted the t-stat on the passenger side, you had to use a 180* fitting.
Did you try to mount it in the same place, but on the driver's side, to avoid the 180* turn? Did that not work because of a clearance problem with the upper radiator hose?
Replica is not a dirty word.
