Originally Posted by stephen low
Your suggestion is much the same as Nasty's and it may have merit.
That's the pedal ratio you are changing. Measure what your pedal ratio is and compare it to someone else with similiar brake setup. Should tell you whether you are in the ball park. I've got a similiar brake setup, so could measure my pedal ratio for you if you are interested.
