Old 10-26-2007, 11:53 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Use a standard pump with standard clearances. You'll be glad you did. All an oil pump has to do is provide 10 psi per 1,000 rpm, which is easily obtainable with standard bearing clearances. More volume means lost power to the flywheel and extra load on the oil pump/distributor drive gear. So don't fall into the trap of using a high-volume pump.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
