Old 10-27-2007, 02:44 PM
Bailey's Avatar
Bailey Bailey is offline
Cobra Make, Engine: Backdraft #985 Custom Pro/ Street Race Car, full cage, dry sump 427W and G Force T-56 Fully Street Legal!!
Like Jim said.
Check to see if the whole column is moving, or the steering shaft within the column. There is an upper and lower bearing, both BMW parts. I have replaced both. I believe the carriers were plastic, and with some wear and vibration caused by improperly balanced wheels, it might be what is going on.
Next the cowl brace and windshield are bolted in. Verify that ALL the bolts are tight. I check mine every few months. Even with lock nuts, they seem to loosen up.
Also follow Jim's advice again. Check the U bolt clamp that secures the column under the dash.
Keep us posted,
Richard Bailey
Life is short, live like you mean it!!
Live every day like it's your last. One day you will be right!
