Thanks...great idea about the windshield and cowl brace...they're definitely rattling. I'll check the steering column bearings, good to know there's a wear point in them.
Tonight I pulled the front wheels and had a look at the shocks and springs. I have the 12mm springs and they're set at 57mm between bottom of the spring screw to last thread on shock. That looks right in terms of wheel fitting the fender when driving...not sure what others are doing. The right front shock is oily and dirty, so I think it's leaking and gone south.
What's a good replacement shock for street use? (Don't mind a stiff ride.) and are the 17mm spring coils good for street driving?
Thanks,
Tom
PS: also found that the header from #8 cylinder (back right side of vehicle) is very close to the foot box (1/8") so there may be some banging on the fiberglass too.
2+2=5 for very large values of 2
