Thread: tire pressures
Old 10-29-2007, 03:36 PM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
If you think BFG 15" tires are round then you have not experienced tires that are. In general they exhibit more problems than others. And beyond that it is often the wheel. If you have no problems balancing up a set and getting no vibration you should consider yourself extremely fortunate. Backdraft does not make wheels or tires though. No google needed, it's all right here.
I pay quite a bit for those occasional banners ... but the stink continues to roll in off the "C". If you think 3 - 4lbs. is inconsequential then you obviously lack math skills and/or actual driving experience.
The key to finding the correct tire pressure for you is experimentation. Roads and conditions will vary with climates and temps. Many people report 28psi as good... try it. Then try 26psi... when it works it works. You have very little weight to worry about.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
